I have a pumphouse with an outlet at it where I want the docking station. This sits in the middle of an existing area. The pumphouse has an NGZ around it but I would like the option of putting the docking station there next to the pump house but keep the area mow-able. This seems to be a limitation r/n. Maybe a feature to allow to map the docking zone so it’s not in NGZ and not in mow-able Area.
You could map around this but you’d have a line segmenting the yard. Or do it in 2 halves.
Thanks for sharing your thoughts. We may not consider this feature at the moment, but I’ll keep an eye on it and see if more users show the same interest.
@bryan.wheeler likely has the best workaround, but if you share a pic of your map others might have some clever solutions as well.
Thanks for the reply. This is what I ended up doing - splitting into two halves. Creates some extra lines in the yard but was able to move the docking station.
What if you delete the ngz then redraw but around the back of the dock area? Is that what you meant by splitting?
