Adaptive slope is always on?
Is it right that we can not power off adaptive slope?ok we can power off but it is ON. The video is with adaptive slope off. Ok there is 6 degrees slope but in this area Not necessary to drive so slow. So also my Per Area adaptive slope and adjustable is significant. Your yarbos drive also very slow downwards with adaptive slope off. ??
I believe it is a bug that it doesn’t disable
I think it partially turns off, not sure the circumstances, but Yarbo has said they will fix it. The oddest thing is that it turns on in areas that I wouldn’t even consider a slope. Maybe it was even a side tilt rather than a slope down, and it was crawling. One of Yarbo’s overcompensations to the voices yelling about missed areas on slopes.
this is the video
Looks like it’s seeing the tree and slowing down in the first video. Possibly the post in the second and then the weed in combination with the steep slope. Just my theory.
Every line the same with or without tree
I would recommend enabling issue record. Reproduce the issue and note the times it slows and resumes full speed. They should be able to correlate from the log why. Disable the issue record after you reproduce the problem and let them know in your ticket that you recorded the issue and the times. That with your videos will definitely help them narrow down what it going on.
I have done that
I’ve reviewed your support ticket regarding this issue. As we discussed there, this behavior will be optimized in the next update.
Regarding your suggestion about having a slope pattern button for each area, we’ll also share this feedback with our team for consideration. We truly appreciate your understanding and input.
