B010 error
I’ve used my Yarbo 2 times and now it had a B010 power board error
Did you hot swap the module (unplugged or connected it when the core is powered)? If so, that can trigger that. Try unplugging the battery cable for 5 mins and reconnecting. If that doesn’t reset it, hold the power button for 60 seconds. If it still has that error, then power down and try a different module, like the SAM. If the second module has the error still, then you need to submit a ticket to support for them to diagnose what’s going on. If it’s just related to the module, could be something with the module itself. Again, a ticket would be needed. Probably couldn’t hurt anyways for them to check it out and be sure.
Bryan has already provided guidance on the initial troubleshooting steps, so please refer to his reply and try those first. If the issue is not resolved after completing the troubleshooting, please submit a support ticket with all relevant details, including the steps you’ve already taken. This will help our support team assist you more efficiently.
They sent me out a refurb, so we’ll see. And no, I’ve never hot swapped it to anything. I only have the snowblower. It was having problems with it’s GPS and the snowblower module stopped working. It would still move, but that was it.
