Can't Access Either Yarbo Remotely Since App Update
I recently updated the Yarbo app and ever since the only way I can connect to the units is if I am nearby (within Bluetooth range). Both units show HALO when running - one is on the data center and the other is on NetRTK. Both will run their respective work plans as long as I am within Bluetooth range but up until the update I could connect to them from anywhere. When I open the app, both show offline. When I click on the first one (Yarbowski) I get the spinning logo, then a message stating “Network Issue. Please check your router to make sure WiFi is working. You can also try switching to Cellular for a better connection”. If I then try to connect to the second unit (Mowbowski), I just get the spinning Yarbo Circle. If I close the app and select the second unit (Mowbowski) first, I get the same Network Issue error message and then I only get the spinning Yarbo logo if I try to select the first unit (Yarbowski). I only had these connected to the network during setup and then deleted the network from both as they are using HALO. Again, this happened immediately after updating the app and I am not sure what to do as we travel frequently and have always been able to access both units from wherever we were.
Yarbo is down right now, nothing you can do but wait it out till they come back up, that is if you are trying to connect this am.
Thanks. I just saw another post “Yarbo Down” that covered this. Should have read the entire post instead of just skimming the headline. Sorry for the duplicate…
No problem, just didn’t want you to think it was something on your end when it is a yarbo issue.
Ah, that explains it! Thanks for letting us know.
