Yarbo Down
Can’t see any of the three rovers I have access to today. App opens but no connection to cores.
On the bright side, my Lymow still works!
This is why we need local control of our rovers!
Yep! Got the same thing going on. I received the firmware update this morning. Now I can’t connect via anything but BT. Boy am I glad they switched off local access! Within a couple days we’re all dead in the water. This is the exact scenario we were afraid would play out. Disgusted doesn’t begin to express it.
I seem to have the same issue. Can this be with the new update? The app opens but indeed no connection to Yarbo and it says ‘Network issue. Check your router or wifi…’ But all of that is working fine.
Local network communication with the bot was DISABLED in this update. EVERYTHING now goes through Yarbo cloud. The single point of failure just failed!
We need local access of OUR equipment!
Mike from Yardstick here. We have been measuring this since about 7:15 Central and can add some detail.
What we can see. Since 7:37 we have retried a connection once a minute: none accepted. The refusals come back three different ways, mixed together. Sometimes the encrypted handshake is cut off partway through, sometimes the connection is reset outright, and eight times their broker answered properly and said “Server unavailable”. Meanwhile our recorder, which connected before this started, has never dropped and is still receiving telemetry right now, position, battery and signal strength.
What we think that means. This is a reading, not a fact, so take it as such. Their broker is clearly alive, because it is answering and telling us it cannot take the connection. And the message path is fine, because sessions established earlier are still flowing. What appears to be broken is specifically the step where a new connection is accepted and authenticated. Anything already through the door keeps working; nothing new gets in. The three different failure modes look like a front door shedding load unevenly rather than a service cleanly switched off.
If that is right, one thing worth knowing: every app retrying every few seconds lands on exactly the piece that is struggling. If you can bear to close the app and leave it alone for a while, you are probably helping it recover faster.
Practical side. Nothing to reinstall, nothing to reset, and a password reset will not help. If something of yours is still showing live data, that is an old connection still running, so leave it alone rather than restarting it.
On local access. We are pushing for a secure, properly authenticated local path, and today is the argument for it. Our own product goes through their cloud too since they closed the local access and is just as stuck, so I am not selling a cure. I am saying we would like to build one and it needs Yarbo to open that door.
Same here, no access to Yarbo.
Thanks for the update @mike1 . I installed Yardstick yesterday and will happily subscribe with this great customer service.
How long would you recommend leaving the app alone?
If you are connected don’t close it. We are monitoring this from our side and will post as soon as we know things are up and running on the Yarbo servers. In an outage like this it may even come up then crash back down depending on what the issue is so we will try not to give an all clear until we know for sure. Hopefully Yarbo will let us know also.
They are currently looking for the fault at Yarbo; let’s hope they can restore the connections quickly.
What bugs me about this yarbo failure, is the fact that the error that comes up states it is a problem with your network, not that their side could be the issue.
It’s user error. C’mon :slight_smile:
Same here, under Diagnostics in the app (connected over BT) it says the MQTT Server is disconnected. The latest update from Yarbo says the “removed legacy MQTT Servers”…coincidence?
indeed!
Maybe, maybe not, but the timing is sure suspicious. One possibility is that the update may have dumped a bunch of new connections on the system without properly load testing it. We’ll probably never know for sure.
Come on now, yarbo always tells all the details in everything they do…
Just remembered you can’t even start a plan from BT since the Plan Name to Plan number translation is stored in the cloud. The Plan List is BLANK. It is truly DEAD without an internet connection. This is the worst situation possible. We all have Yard Bricks.
Edit: I’m told this may not be accurate. Apologies if incorrect. I was pretty livid this morning and didn’t temper it well :slight_smile:
I love how Yarbo has left it to us to figure out their shite is broken. Complete official silence on this forum - Way to roll someone out of bed and get ahead this. A helpful third party has to jump in to tell us what’s happening. Yet another instance of total communication failure. They’ll never get it.
It is sleepy time in china, give em a break.
Sorry, but have to disagree. There is no sleepy time in IT when systems go down. They haven’t even sent an Outage email - unless that’s down too :slight_smile:
