Using NetRTK and tried on both wi-fi and cell. I drive the perimeter of the map, then when I get to the starting point again I click “continue”. It spins for 20-30 seconds then comes back with “Request failed, please check your network.” Must have re-mapped 5 times, and get the same behavior. As you can see from the image, I’m connected to the rover by bluetooth and I have strong GPS signal. What does the network error mean? What network?
Disable bluetooth temporarily either on your phone or for the Yarbo app. It’s probably that connecting and disconnecting causing you some grief.
The “Request failed…” is just a generic the app can’t communicate with the server or the core error message. Typically this could be because you lost internet, your phone is switching from bluetooth, to WiFi to cellular, etc. Could also mean the core is switching networks too.
Interesting. But if I turn BT off, how do I drive the mower to map the perimeter?
It should connect over your WiFi or cellular to control it. If find Bluetooth laggy and buggy at times. It is device dependent though.
Hi there, you can follow Bryan’s suggestion to see if that helps. If the issue still exists after the trial, please feel free to submit a support ticket and we will further investigate it and help you resolve the issue.
