Mow order
  1. The map often ends at a point very far from the charging station. It would be good if Yarbo could end closer to the charging pad.
  2. lt would be good if Yarbo mowed the small areas first and ended with the larger sections.
    … Both of these changes would help avoid crossing the counter of the lawn multiple times and messing up the beautiful straight lines Yarbo makes on the open areas.
Thank you for your valuable feedback!
We completely understand your concern about keeping the mowing lines clean and preventing Yarbo from crossing over already-mowed areas unnecessarily. Currently, the endpoint after Yarbo finishes mowing is determined by the route calculated by our algorithm, which can sometimes lead to the endpoint being far from the charging station and difficult to adjust manually.
That said, we do recognize the need to minimize Yarbo’s travel across areas that are already mowed. Our product team is actively working on route planning improvements, including the possibility of having Yarbo move between areas—or from an area back to the docking station—along the perimeter rather than crossing open lawns. This would help preserve the neat lines you’re looking for.
As for the mowing sequence, you can currently reorder the areas Yarbo mows by simply dragging them in the app, giving you control over which areas are completed first: How to Use the Smart Sorting Feature with Your Yarbo? - #10 by steve
We truly appreciate your suggestions and are always working to enhance your experience. Thank you again!
