Copy no-go zone
This has probably already been suggested but I couldn’t find any references to it. It would be nice to be able to copy a no-go zone dimensions so it could be replicated without having to resize it everytime. Example use case would be you have a row of trees, bushes, etc with the same perimeter size. Create 1 NGZ and copy then position it for the rest.
Thanks for your suggestion! I’ll pass this to our product team. If more users are interested in this feature, we’ll definitely consider it for future development.
I would like to extend this request to be able to copy any artifact in a map (maybe areas are not needed). Particularly no go zones and dead ends.
While we’re at it, it would also be nice to be able to edit no-go zones and have the ability to create them the same way you can create a geo-fence. I have some oddly shaped NGZ’s where a rectangle or circle don’t work and it’s impossible to drive the rover around to ‘draw’ it.
I have some map areas that I can’t drive through the parameter to edit the map. Well without removing fences and flower beds.
Sounds like you don’t need to edit the map then. Unless you want it to mow your flowers. :joy:
