Creating a vaccum option for Yarbo
In my neighborhood we are not allowed to use blowers. It seems you would have a good base platform with the blower to create a vacuum system. A nozzle the width of Yarbro body would be nice for larger yards. I would like to see a 10’ hose extension and megaphone nozzle for cleaner areas Yarbo can’t access. A removeable bagging system built off the hitch would work nicely. Again, for larger yards a trailer on casters to follow behind may work. This is an accessory I would definitely purchase to use with my Yarbo.
Thank you so much for sharing your feedback! That’s a really interesting direction. While this specific vacuum system concept may not be in our short-term plans, we truly appreciate the thought you put into it and the inspiration it brings to our team. Suggestions like yours help shape the future of Yarbo!
Could a towable sweeper or leaf vac work? Yarbo is coming out with the refined towing logic. I’m excited for that too. I can run the broadcast spreader when that is released.
Anything that is self powered and doesn’t exceed the tongue weight or recommended towing weight should work just fine manually today and in 2 releases tow mode should be available.
Careful…. that almost sounds like a timeline. :wink:
A towed spreader is what I’m looking for. Come on Tow Mode!
Yeah, I did notice no expected dates were provided :frowning:
I could spray some stuff. Looking forward to its release.
My hope is that next release would hopefully address that issue and hopefully others like it and then release after next is tow mode, as the moderator promised this morning.
