Cutting discs wiggle
Not sure should there be such ‘play’ in the cutting module. Have not noticed this before therefore asking if this is normal, or something came loose.
That looks normal to me. Are you hearing anything out of the ordinary noise wise?
Hi there, have you noticed any other abnormal behavior besides the movement you mentioned? Based on what we can see at the moment, this amount of wiggle appears to be within the normal range.
Thanks! if you say it’s normal, then I’ll believe :slight_smile:
