Cutting Disc lock during maintenance work
Maybe this exists and I don’t know about it, but it would be helpful if the cutting discs could be locked in place to prevent spinning when you have to replace the blades, replace the disc itself, etc… At this point I have to hold the disc and try to prevent it from spinning in my hand while I’ve replaced blades. Unfortunately it’s slipped a few times and I’ve cut myself on the blades. If there’s a solution to this already then someone please share. :slight_smile:
Doesn’t exist. Use gloves to hold the discs when you remove them.
There is already a request for this, pls find it in forum and like it instead of creating duplicates.
Wasn’t my intention. The system also searches as your typing the description in and nothing came up. I also did a search but came up with nothing but maybe it was the wording I used in the search. I will search again and see if I can find the post you’re referencing. (You can also link to it, I believe, in your message. :wink: )
Yeah, no worries, I think they’ve already decided that was a good mod to make, just waiting for implementation. I think there are actually a couple entries like it. I had made one quite a while back, then I think there’s another lingering in there somewhere. It’s not perfect at catching dupes. It’s quite a hazard though, especially if someone isn’t wearing any work gloves. Have fun and hope you have good luck with your system. So far so good with mine, only big issue so far is a stripped screw on the center of one of those discs. They really over torque or use too strong of a loc-tite for their hardware (IMO). Still gotta work that out but not an emergency. :+1:
Yeah, I was dumbfounded how hard it was to get that initial “break” on the screw to begin removing them. I’ve, unfortunately, had several issues. Support has been pretty good about helping to resolve them. (Already had my core module replaced once because it did the whole won’t auto charge anymore after an update.)
Ugh, sorry ya had that happen, but knock wood, so far my systems been solid.
You can download these for free from Thingiverse and 3d print them. Much easier to maintain and mulch well too.
They are list under Yarbo.
I’ve run into this as well. No worries.
