Dirty camera causing false obstacles
Anyone have a suggestion of what can be put on the camera so dirty doesnt stick? I tried wd-40. I end up having to wipe it nearly daily. Its causes a lot of false obstacles it spends 15 minutes or longer distracted with.
After confirming with our support team, we do not recommend using WD-40 to clean the dirty camera. Instead, you can use a soft cloth to gently clean the lens.
Yeah I agree with Yarbo here. That would probably make things worse. I’d get some ceramic coating and surface prep. Adam’s polishes makes a nice kit. This will help but nothing other than routine cleaning will fully help. If you are ok with bumper only mode, that will negate the need for cleaning the camera. A hose or wiping it periodically otherwise.
