I’m having a few issues with docking the mower core in the last few days
My questions are;
What’s going on and why?
Is a new charging pad needed?
Given –
- (deleted)
- Currently Using NetRTK for positioning
- App Version V3.19.5 (current version)
- Firmware Version V3.14.11 (current vision)
- Currently using a single RTK Antenna Pro on the left-side antenna mount, looking from the rear of the core.
- Using two RTK Antennas create a “network” conflict causing the core to stop and sit idle after 9-10 min. of usage. Loosening and retightening the right-side antenna will start mowing process. However, the core would only operate for 9-10 min. without having to repeat the process. So, the right-side antenna was removed and the starting and stopping has improved (somewhat).
- The charging pad has not been moved since being installed 11 months ago.
- Pictorially the App shows the core parked charging pad. Except for when the core was manually centered on the charging pad. App shows the core parked just off to the side of the charging pad and unable to charge.
- Up until three (3) days ago, the core had no issues docking on the charging pad.
- The core has been power cycled several times for 10-mins or more
Background -
Newman was set to mow an area late in the evening. The task was completed around 8:30 pm. After that, I believe Newman had a night out and a triple dose of electrolytes. In the morning I found him fully charged and askew on the charging pad.
(Parking from 8:30 pm mowing. The Core was able to charge)
After a firm reprimand and discussion on who controls the power, he was sent off to the furthest area of the yard and was parked for 10 minutes. I then initiated a recharge cycle via the iPhone App. When Newman returned and attempted to align on the charging pad, the recharging attempt failed. I shut down the core and did a power cycle for over 10-min.
After about a 10-minute waiting period, Newman attempted to align itself again on the pad. After the Yarbo Charging Pad Dance, Newman was left askew on the charging pad and charging.
(Parking from a rechange attempt. Newman was able to recharge.)
Newman’s positioning on the charging pad from the 11:45 am attempt to the 11: 55 am attempt were similar. Measuring from the center of the front bumper to the garage door, the front edge of the 11:55 am parking position is about a 0.5-inch closer than the 11:45 am attempt
After mowing the largest section today, Newman was able to return to the changing pad and start the recharge cycle. However, it was again askew on the charging pad. Measurements of the front bumper to the garage door matched the distance from the 11:55 am attempt.
(parked askew on the charging pad but was able to recharge.)
After manually centering Newman on the charging pad, the App showed Newman parked just off to the side of the charging pad and unable to charge. I performed a power cycle for over 10-min. and restarted the core and moved Newman into the garage waiting for 3 days of rain to pass
(manually centering)
