No power after replacing RTK antenna
I was having the Yarbo mow my lawn and forgot to raise the swings and a swing caught one of the RTK antennas and broke the threads for the RTK cable. I had the Yarbo fully charged, moved it to my driveway, unplugged the battery, opened the case and removed the broken RTK antenna and then replaced it. When I lifted the top off the unit, the J10, J19, and J20 cables came unplugged. I plugged those back in and put the top back down and screwed all bolts back in. When I went to power on the unit, nothing happened. No power, no response of any kind. Anyone else have this issue? I first bought my Yarbo in November, and this core is the second unit, as the first one was replaced already. This second unit appears to be a new unit, as we were within 45 days of the first one for replacing it.
Going to ask the obvious questions that I’m sure you probably already validated. Are you sure the battery is charged? Did you check and make sure that all the J# cables that were unplugged are reseated properly as well as any other cables and connectors? I’d also check and make sure no cables were pinched when the cover was reinstalled. If everything checks out, I would try connecting the wired charger for a few hours. It should be solid red when charging and solid green when fully charged. Then try holding the power button for 60 seconds to see if it tries to turn on.
Hi there, you can follow Bryan’s suggestion first. If this does not help resolve the issue, please feel free to submit a support ticket so that our support team can help you.
