does spiral pattern auto adjust?
Does Yarbo have any feature that adjusts the spiral pattern after each completed plan? Or does that only work for parallel patterns?
Only for parallel style patterns currently. There are some feature requests for this.
Was looking at the Dog Pen, which is Spiral because it’s an odd-shaped small-ish Area. I would like to see the Spiral pattern rotate.
Speaking of spiral…Why does it leave a strip in the middle not finished? I have to areas I like to use that setting as it is long narrow strips, but it leaves the same strip every time it cuts.
Is the strip on a hill? If so that bug is being addressed with the latest update…
Tim
No hill, flat land. You can see on the map it makes there is a wider space between lines at the center of the pattern.
Seems like a bug. You should submit a ticket if it still does it on the new firmware.
IF, I ever get the new firmware is more like it. They sure like don’t like sending to Yarbo’s in Wisconsin. I just started using the spiral mode recently as two areas I mow are very narrow (like 20 feet or so). If the Yarbo mower turns every 20 feet it takes forever for it to mow these areas. I will try it again after I get the new firmware and it stops raining, lol.
So looking at this, I really agree. I was using the new updated one in one of my areas. But really like the spiral better in two of my areas. Once it done today, I’ll put him on the other one. My only gripe is when he gets done. He tracks outward from the center, thus leaving a nasty looking track mark. If he started these areas from inside and worked outward that would be great, and look great. I have one area with nothing, No NGZ. So when it’s cut, it looks great, well besides the tracks on the way out. So rotate would be great. Or just start inside and work outward. Just my two pennies.:wink:
Did we ever get an update for spiral mode. Work from the inside out? Also how about working clockwise one cut, and counter clock the next time it’s cut? If I missed it please excuse.:wink:
Not that I can recall
Alright cool. Still would be a great idea. Just wanted to know. I’ve missed the forum. Been super busy in life. But really glad we’ve get getting some better updates. Still working on issues I see, but at least we have a place to talk about them. Thanks so much for your help.
