So looking at this way of mowing. I really like the pattern. I was using it on a couple my areas. I really like the spiral better in two of my areas. My only thing I hate is when he gets done. He tracks outward from the center, thus leaving a nasty looking track marks. If he started these areas from inside and worked outward that would be great, and look great. I have one area with nothing, No NGZ. So when it’s cut, it looks great, well besides the tracks on the way out. So I would suggest a rotate would be great. Or just start inside and work outward.![]()
Yes an auto rotate option on direction of the spiral and starting at the center would be ideal.
Thanks for sharing your suggestion and detailed feedback. I’ll help pass this along to our product team for further evaluation and improvement.
I can see wanting to change the spiral direction, but that might cause problems if you have the trimmer installed as it only hangs off one side. But changing the start/stop points would be nice in addition to changing the start point between “center” and perimeter.
trimmer enabled auto forces it to clockwise on the perimeter now, or it should. But I would be OK with it not trimming if going counterclockwise for one mow. Trimming doesn’t need to be done but once every few weeks (at least for me).
