Hi, So I have my areas created, throw direction set, and fake dock station created, but when I start a plan, it tells me failed to calculate route. What have I missed? Help will be most appreciated!
Do you have paths from your areas to your docks? If you have more than one area, do you have paths connecting them?
Also, If the virtual dock doesn’t have good GPS you won’t be able to calculate the route.
Hi there, are you still experiencing the issue?
I saw in your other post that creating a pathway for the virtual docking station solved the problem.
If you run into anything else or need further help, feel free to let me know!
It was indeed a missing path - thanks! Just not a clear error message.
Thank you!! Yes, it was a pathway issue. A clearer error message would have been helpful but I sorted it out pretty quickly. ![]()
Have it snap you to the location of the error needing correction?
That would be handy. Might need to snap you to several places thought. One at a time I guess as you fix them?
Exactly. Until there are no more misbehavers.
I think I’d prefer for it to highlight the errors on the map and then let you click on them. This would give you a holistic view. Also, I personally don’t like when software auto adjusts views on me. That’s probably just a personal preference.
