Yesterday and today Andrew worked very well. We had a long and very cold period here with very little snow. It was so little that the use of the snow blower would not have been worth it. There has been about 8 inches of fresh snow in the last 2 days. Together with the snow that was already lying there, it was a considerable amount, but Andrew worked through all the work plans. Today I noticed that all the lights and the flashing light on the charging station remained on while charging. Does this happen when you turn on the frost protection?
It doesn’t. There’s a known issue they posted in this firmware about the lights remaining on until it enters idle mode after docking and charging. However that doesn’t apply to the flashing light. If you know the times, I’d recommend submitting a ticket so they can pull the logs.
Thank you, i opened a ticket: #164139
