Im having some GPS issues. Here is some screenshots. Anyone have an idea why?
I’m out of ideas really.
Somehow the rover however is still running on 3.12.0 firmware and hasn’t updated itself. Phone application was updated couple of days ago when hotfix was released.
Do wired charger to the back of the rover and Wi-Fi turned on help to get it finally initialize the update?
I have. Also disconnected everything for about 3 hours but still nothing.
DC shows green color so should be ok on that end.
Also no update still.
I remember I had similar problem already at least once. Where the phone application was updated and the rover was using still the old one. Had connection issues and also GPS issues at the same time
What does your HaLow section of the diagnostics look like? Also does the network section say connected or disconnected. There is a lot wrong in this diagnostic snip that you posted. Right now it looks like the DC but it also looks like the core isn’t communicating with the app.
This issue may require further investigation from our support team. I’ve checked your ticket in our system, and it looks like your current request is mainly about the firmware update.
For the GPS issue, it would be really helpful if you could submit a separate support ticket and include all the troubleshooting steps you’ve already tried. This will allow the team to better understand the situation and assist you more efficiently.
Appreciate your patience, and we’ll work with you to get this resolved.
Do you have a ticket? What’s your ticket number? Have you tried any of the troubleshooting steps mentioned here? Diagnostics screenshots would be helpful.
That looks like a bad RTK antenna to me. If you swap left to right and right to left the L2 numbers should go from zero to something above 10 and total satellites would drop to zero. Right now it seems like it’s the right antenna (as you face the rear of the core). If those numbers change when you swap them, that’s what it is.
Or, since he had satellites before but no L2, it could be one bad RTK antenna and one bad cable or antenna mount.
@tkakavros something else you might look at is the actual mounts for the antennas on the rover. I had a similar situation when I was initially setting up my rover. I made a post about what I found here: A journey to get here... - #38 by balmerjd
You might take a look and see if you have the same mechanical issue I had.
