HaLow Antenna for Rover | Yarbo Accessories
My antenna broke at the copper threads. The link for a replacement shows the top section but every post shows the yarbo being opened up and the cable being detached from a post under the plastic cover. How do I buy that part?
I have had this issue. It is quite a easy fix. Just need to replace the cable. You are in need of SMA female that has 90 degree angle and other end needs to be SMA male. I bought this cable from local hobby electronics shop for about 5 euros. They only had 30cm long version. They also had some 90 degree adaptors for shorter cables but I preferred already factory made cable with correct pins.
Yarbo did send me a replacement but it took ages. I still have it somewhere. If I remember correctly it was roughly 20cm long.
Yarbo wiki has the video how to open the core correctly to change this cable
Perfect. Amazon click, should be here later today,
Same issue here. Do you have a link for the cable that you could share? Thanks
Get a ticket opened. Yarbo will send you a replacement kit.
Amazon link. The 6mm Allen wrench bolts are harder to undo than expected though.
Ticket #201967 submitted. @Yarbo-Forum TIA for keeping an eye on this one.
Received the replacement antenna and wire. Can anyone point me towards the video showing how to replace them? Thanks.
