Need the base connector for the Halow antenna
Found my antenna broken off leaving just the core insulation and no way to connect the halow antenna for rover (y series) that I thought I needed.
How do I order the block with the Halow Base?
(I did email support on Tuesday, no word back)
looks like I need this
You can find this cable on amazon.
I will copy here the solution I wrote to similar problem:
I have had this issue. It is quite a easy fix. Just need to replace the cable. You are in need of SMA female that has 90 degree angle and other end needs to be SMA male. I bought this cable from local hobby electronics shop for about 5 euros. They only had 30cm long version. They also had some 90 degree adaptors for shorter cables but I preferred already factory made cable with correct pins.
Yarbo did send me a replacement but it took ages. I still have it somewhere. If I remember correctly it was roughly 20cm long.
Yarbo wiki has the video how to open the core correctly to change this cable
I’m sorry for the delay in response. I’ve asked our team to review your case and arrange a replacement as soon as possible.
To help speed things up, could you please send us your latest shipping address through your support ticket thread? This is our standard procedure whenever a replacement is needed.
Thanks for your patience, and we’ll make sure to get this sorted for you quickly.
