If you have over 2GB of cellular data usage, they turn it off when it hits a certain cap. If there is no usage, then check that it is enabled and shows status 1 in the diagnostics.
Hi there, great question—this is exactly what the “Next Run Behavior” setting is designed for ![]()
In your schedule settings, you’ll find an option called Next Run Behavior. This setting determines how Yarbo handles the next run:
Resume from last stopped position → Yarbo will continue from where it left off (ideal for multi-day schedules like your 2-day plan)
Restart from beginning → Yarbo will start the schedule fresh from the beginning
This gives you flexibility depending on how you want each run to behave. Let me know if you’d like help setting it up ![]()
Thank you! It loos like the resume where left off is the correct setting needed.
Yes, you’ve hit your cap. Submit a ticket and they can add more data.
“… and is not supported for the SAM module.”
As Bryan suggested, please submit a support ticket for this issue, and our support team will be happy to assist you.
If you’d like to see this feature available on other modules, feel free to post a topic in the “Suggestion and Feature Requests” category. We’ll continue to monitor community interest there to help guide future prioritization.
Looks like gentle contact is the best mowing option… otherwise yarbo sees some ghost obstacles, loses his mind at some point and starts going in circles. ![]()
A bit ridiculous behaviour.
Unfortunately, yes. Looks like there were some splotches on the front camera probably contributing to that. If you submit a ticket with the times they can pull the logs and confirm and hopefully get enough reports to do something about it.
Has everyone gotten the firmware update? I’m still on 3.11.0 (replacement core). I have a ticket open, but nothing is getting pushed.
Everyone should be at this point. I imagine they will get yours updated next week.
I hope so. I’d like to be able to set some of the various options (like mowing speed and path offset) now that I have a fully working core/setup.
