Has anyone had a chance to test this out on Dead Ends or Memory Paths that were backing in previously?
Do you have the core connected to your home WiFi? When you say it can only connect when you get close, you mean the app or GPS on the core restores and it starts mowing again when you get close?
I have no camera signals after the new firmware release and an imaginary obstacle that prevented the Yarbo mower from starting a mowing task. Did not have these issues previous to this new release.
I would try disconnecting the battery for 5 minutes then reconnect and restart the rover.
Sometimes these things just need a reboot after updates.
try restarting the rover
Typo, battery disconnect
If you did a battery disconnect after the firmware and still no cameras, I would open a support ticket. Hopefully they can take care of you in a timely matter.
Do you see a HaLow icon when you open the app or something else like WiFi or 4G
Does it say no signal, not connected, or is just black screen?
Are you doing any regional blocking or other firewall type blocking on your home network?
Not that I am aware of. The cameras were working fine yesterday and no previous issues with them.
I would try the battery disconnect again and see if that fixes it. Otherwise it sounds like a ticket is needed.
Will do that later after it finishes up the remaining lawn cutting.
Not to pile on here but since the update I have gone out of bounds twice and failed to dock once. So even though my GPS is amazing the software update managed to screw with that even.
I hate to say this but whoever is in charge of your software development should be “pursuing other opportunities and Yarbo wishes them the best”. This is not getting better @Yarbo-Forum unless you like dumpster fires.
Yeah I finally got mine to mow today after being forced to remap the entire yard again, “lost all of my maps after the firmware and app update yesterday, again..” started mowing, looked good so i went inside, until it went right inside of a no go zone as if it didn’t exist and ran over and mowed drainage pipes to my road side gully, and ruined them cutting the tops off, and wrecked the blades on my new pro mower, it got stuck on the pipes and some how rolled itself over backwards. F’ing ridiculous.. I’m so ticked off..
Oh yeah, Istill can’t open a ticket in the app I get some random error, tried about 12 times in the last 48 hours..
I’ve just finished cutting my entire 4 Acres without issue after the all the updates, and I have some areas with sketchy reception. I’m not discounting any of these reports but the wildly different results just make no sense to me. Does the software have glaring issues, you bet. I stilk can’t square the crazy variances.
The suggested battery disconnect brought back all camera views. Thank you.
