We’re pleased to let you know that Firmware V3.14.0 and App V3.19.1 are on the way. The firmware update will be rolled out in batches within one week.
What’s included in this update?
Firmware V.3.14.0
New Features
General:
Introduced Tow Mode (Beta)
Added Single-Antenna Positioning Mode to improve positioning reliability.
Optimizations and Bug Fixes
General:
Optimized path planning when heading toward No-Go Zones (NGZs) to reduce lawn damage.
Optimized obstacle avoidance behavior when the cameras are dirty or obstructed.
Optimized visual obstacle detection to enable earlier speed reduction when approaching obstacles.
Improved network connection stability.
Fixed an issue where Yarbo could enter No-Go Zones (NGZs).
Fixed an issue where Yarbo could deviate from boundaries or go out of bounds.
Improved map calculation speed for large maps when starting Work Plans.
Fixed an issue where enabling Pathway Offset could cause route calculation to fail.
Fixed an issue where voice prompts could become unavailable.
Fixed an issue where scheduled tasks could fail to run as expected.
Improved the lighting logic for a better user experience.
Lawn Mower (Pro) &Trimmer:
Optimized turning logic for smoother and more efficient path execution, with reduced turf damage during turns.
Fixed an issue where Checkerboard pattern did not automatically rotate 90° during the second run.
Blower:
Optimized route planning to reduce unblown leaves.
APP V.3.19.1
New Features
General:
Added APN configuration support for 4G cellular services.
Added a Map Cloud Sync & Sharing toggle in Privacy Settings with a user consent prompt for cloud map backup.
Optimized Bluetooth connection stability for a smoother app experience.
General:
Optimized the No-Go Zone editing interface for a better user experience.
Fixed an issue where the app could log out when viewing the work plan history page.
Fixed an issue where the Expand Area feature could fail to work properly.
Fixed an issue where the starting point (green dot) of a mowing work plan could disappear.
Fixed an issue with false lift detection errors.
How to update?
Ensure your Yarbo is powered on and connected to the internet. The new firmware will be automatically downloaded and installed once it becomes available for your device.
If you have not received the update within one week, please contact us at support@yarbo.com for further assistance.
Immediately after the update, it started doing a scheduled WP that it had already successfully done this morning (it was past the scheduled-start-time). Kind of weird…but not so bad, plus the schedule is a window, and it is still in that window of time — so not something to complain about much, if at all.
The real trouble is, Yarbo has completely gone off into the wild, out of areas, paths, etc!!!
If I hadn’t been watching it and stopped it might have driven into a ditch.
Yarbo isn’t a hobby for me. I bought it to DO WORK. I’m still waiting for it to at least meet me halfway.
Hi, I also received a new firmware update and it seemed to go through normally and I updated the app, but the app still shows the old firmware versio (3.13.15)? I tried, normal restart, 60sec. restart and remove battery +5min restart to Core, but no help here.
I am sure they will write a primer on it soon enough. DISCLAIMER: I will say that it still very much a beta and people should test it first before attaching any implements and towing autonomously with it.
That’s what I was just saying last week - I’d rather they take their time and get Tow Mode 1.0 to be a solid release, versus deploying something that’s obviously half baked and unusable.
Does it navigate around obstacles well now? Does it also recognize new obstacles? I just installed new garden lights, and I don’t want it to knock them over
