How to charge the Yarbo battery directly?
To charge the Yarbo battery directly, you’ll need the following items:
  1. Yarbo battery
  2. Wired charger (provided in the accessory box)
  3. Battery power cord
    (available for purchase on our official website: https://www.yarbo.com/products/battery-power-cord
    Once you have these, simply follow the step-by-step guide in the pictures to charge your battery!
This works great to keep a second batteries charge level maintained every few months.
It also enables you to charge up a second battery while the rover is running an automated work plan and then you can swap batteries when the first one gets low.
It also makes it a lot easier if the battery ever dies when the rover is in an inconvenient location and with no access to power. You can remove the battery and charge it where there is power. Once fully charged, you can then put the battery back in the rover.
Please note that the wired charger is not outdoor rated so keep it out of the elements.
