Increases the GPS signal to Yarbo
I do not know, because since setting up the dock in December 2024 I never had a problem undocking or docking. My problem is Yarbo stopping in the middle of a job loosing its RTK connection, or whatever signal…
Once again yarbo decided to stop waiting for RTK. But today it showed a RunningNormal Status.
it stands here
After restarting everything it startet to work again.
In the evening it did another area, did quite well except the one missed stripe in the map, wasn’t in the preview… I choose checkerboard in the settings.
@YARBO-FORUM I still can not reach the support center, actually at the moment I get the above error message when I try to go there.
It seems as if your RTK module is disconnecting or crashing. Very odd to have no GPS readings.
That’s what I’m telling the support guys, but they insist that everything is fine, but yarbo us sitting there NOT fine until I restart. I have the same issue since June when I opened my ticket #102036. It’s just frustrating, I can only get jobs done when I can watch it. I got yarbo to mow my lawn autonomously when I’m not at home in the first place!
Yes I would be frustrated too. Hopefully @Yarbo-Forum or @marco can help get this RTK disconnect issue resolved soonest.
@Deixi Hi there, we completely understand your frustration. I’m following up on this case with our support team now. Could you please keep your machine online and let me know once it is? I’ve already contacted the R&D team directly to look into your case, but we’ll need the rover to be online in order to retrieve the logs.
@Yarbo-Forum please do so. Had to restart yarbo on the charching pad, lost it’s HaLow connection. After that it connected fine and it mowed quite well today. Tomorrow it is time to do the large area where it always has its problems…
@Deixi Hi Deixi, thank you for the follow-up. Our support team checked the logs a few hours ago, but it seems they have already rolled back. We kindly ask you to run your Yarbo as planned and let us know if the issue happens again. I’ll continue to follow up on this and ask our team to review the logs once it occurs again. I understand this can be frustrating, and I sincerely apologize for the inconvenience caused.
