Inquiry regarding map misalignment and GPS coordinates offset
Hello,
​I am experiencing a persistent issue with map alignment in the Yarbo app. I am currently located in South Korea, and while Google Maps is supported in my area, the Yarbo app displays my location approximately 1km away from my actual position.
​Because of this coordinate discrepancy, when I overlay the satellite view in the app, my work area appears on a completely different location, such as on the roof of a neighboring building. This makes it impossible to accurately set up my work boundaries.
​Could you please advise if there is a way to manually correct this location offset or recalibrate the coordinates? I have already checked for GPS signal stability, but the coordinate shift seems to be systematic rather than a temporary signal issue.
​I would appreciate any guidance on how to resolve this.
For the Google Maps view, you should be able to resize and move the map around. It doesn’t automatically line up your work areas to the map. I wish it did, but it takes some effort to line it up and size it appropriately to get close to your mapped areas.
