Is this the "dreaded" map drift at work here?
The DC firmware is still only 1.0.25. Hasn’t been updated in over a year. I doubt it is that. But some DC’s you have to practically get on top of the antenna to get it to show up and you need to be patient for it to pop up.
What if you connect your core to WiFi, does it connect remotely then? What’s interesting is your rover says FALSE under RTK. Must be a delay on the bluetooth connection.
PPVS is broken until you get 3.13.1. Unfortunately.
Never had that issue of distance or delay previously, but I suppose i can get out the extension ladder tomorrow and walk the roof down to where it’s mounted and try that. I just hate walking the roof of my pole building, unless I have to. Previously the DC only took maybe 5-10 seconds to show up. For reference for those who haven’t seen the pictures or don’t remember, this is my setup.
I can try connecting to WiFi and see what happens. The Mode status must have just taken some time to connect as it reads TRUE now. When I took that screenshot the Data Center had only been on for maybe 2-3 minutes. Like I said, when I started the app, it took a good 30-60 seconds for the rover to respond and show its status in the app.
Oh, and the light is steady green on the data center if that helps.
Yeah the green is just kind of a dummy light. Unless it’s moved a certain distance or the RTK internally failed, it’s pretty much always green. I wouldn’t think you’d need to connect to your DC. It seems to be functioning fine. Not worth getting on the roof for TBH. Hopefully if you get the firmware update, it will help resolve this for you maybe.
Oh! NOW THIS IS INTERESTING!
I don’t know how I missed this earlier, but the Reinstall Data Center and Replace Data Center options are greyed out?!?
Maybe still hadn’t fully connected to your core.
But it’s been back up for almost half an hour now, and the HaLow connection shows true… Mode shows true and the DC connection status is 2. Isn’t that all what it’s supposed to be?
It is indeed. So that is very interesting if that is still greyed out. Must be a app/firmware glitch?
Well, at this point I’ll hopefully receive some word from support on my ticket.
Don’t get me wrong, I’m glad that the rover is still working and completing a work plan. I’m just a little worried that this is a bigger issue, and the whole thing is just going to stop working with no warning… and then I’m back to spending 3 hours on a riding mower :sob:
I don’t think you are alone with the weird connection issues. They are aware of this and I’ve seen others complaining about it too. Hopefully gets nailed down soon.
I wonder if it flipped a bit and is set to use network RTK?
Doesn’t seem to be the case with what the diagnostics show. Also shouldn’t impact the app connectivity.
