Lift Detected Toggle
Did the last update fix the “lift detection and roll over detected” toggles that weren’t working properly? I went to run a job today and “Johnny 5” kept giving me a “Module Lift Detected” and pausing my job about every 3-4 minutes. After the 4th time, I remembered the toggles and went into the app to check them and saw that they were both in the “on"Position. I turned off the " lift detected” toggle and retested and it no longer gives me the error message. Was the lift detected sensor always that sensitive or was the toggle always off,even though it showed it was on until this last update?
The toggles would activate and as soon as you hit save they would turn back off. The latest updates fixed it so they stay enabled until reboot. If lift is triggering that means the mower is probably driving over a hole or dip and the caster wheels drop down thinking someone lifted the mower. I have a spot in my yard where this happens so I just leave it off. It can be useful though if GPS has an issue and the rover ends up out of bounds and lifts the module on some edging or rocks or something.
