Lift points on the core?
As I get older l, working on the core is getting tougher. I can’t spend as much time on my knees to care for it and it is too heavy for me to lift it on to a work bench.
It would be great to have lift points on the core so I could use a hoist to assist.
Is there a suggested method for lifting a core?
I use something like this. Drive it on with ramps and jack up the table.
@john.merten1 Removing the module and battery and putting the rover up on its side is how I do the track maintenance, and it’s a bit of a heave, but not bad. The snowblower can be a bit of a hassle to move around, but workable.
That’s me TODAY. I’m in my 7th decade, so what about a few years from now? Has it been your experience that even these basic maintenance/setup chores have started to become challenging?
Seen a few folks use a motorcycle lift. Similar to what cobra posted. Like Ken said most maintenance can be done with it on its side. Removing the heavy stuff really helps.
I should add that I jack this up to my large workbench table height and drive onto the workbench for accessing the tracks from the side.
I like @kmurray6113 front loader idea.
Still working on the wife to get one though…
I completely understand your needs in this type of maintenance scenario and truly appreciate your thoughtful suggestion. I also hope that our warm and supportive community has been able to offer you some helpful ideas or solutions for your current maintenance challenges.
Kubota BX tractor with front loader. Drive it in the bucket, lift it up to your outside workbench and drive it on to the bench. The Kubota can be used for bringing Yarbo back to the shop if it breaks out in the field.
tim
