I am a “noobie” to Yarbo. I have recently taken delivery of a “Y model core” and several attachments including the Lawn Mower Pro.
I am single, and have recently had surgery on my shoulder. I have restrictions on the amount I can lift, and nobody to help..
So are there any hints and tips for installing (and removing) the Lawn Mower Pro module to the core without excessive lifting needed?
Grab it by the back handle and lift gently and wheel it up to the core, then drop the bottom pins into the module (lifting a little). Lift the front of the module up and use it as a fulcrum to push the top pins in. Drop the latches and then lift the front back up a few times to ensure it is fully seated into the pins/latches. It’s a lot lighter this way vs fully lifting the whole module.
Thank you Bryan, that helped a lot.
The issue is to lift the lawn mower enough to get the lower pins in. I tried today with a (low-tech) plank of wood to raise the lawnmower so I can lock in the bottom pins. After that , yes your advice has done the trick.
Awesome, glad to hear it!
