Merge map versions
I would love there to be a way to combine different map versions. Essentially, I want to be able to restore a map without overwriting the current map. Having the option to take a saved map and simply add the areas on the saved map to the current map would be great.
As the maps are tweaked/re-mapped for different areas, I have come to find one version of a map mow one area better than the other and vice versa. In these situations being able to take Area A from map A and Area B from map B to make map C would be great.
Right now the only option is to completely overwrite the old map. Having a checkbox to let the user decide if the current map should be wiped or just overlay the saved map onto the current map without deleting anything would be all you should need!
It would be nice to have an on/off toggle for areas, pathways, etc. like we have for no-go zones.
Save / Restore Current Map came up as a solution to the snowblower to mower mapping issues, but I’ve been told Save Current Map doesn’t save Settings, Work Plans, and probably other things, so it really isn’t a solution.
Yarbo is working on some kind of filtering for mapping. I think it’s going to filtered per the attached module, and I hope that means you can specify which mapped items you want for which module (Areas, No-go Zones, and Pathways are shared across all modules), and they’ll be filtered. But I’ve not heard details of their plans.
