Mower height options
Obviously the area set is simple enough to select height, and the app remote isn’t that big of an issue to use the up and down button…
BUT, it’s also annoying to click the app button or hold it trying to get to a desired height. Could we possibly also have a selection box to click on and just type in the height? 2.2" - mow around this area with app remote. Want to clean the top of deck some after thick wet areas - type in 4" to let the back lift part of blade start knocking as much loose from under deck…
I was thinking the same… it should be a quick set to move to new height
I prefer the old design but all it was lacking is lock out. People were accidentally hitting it and lowering the blades when manually controlling the robot. It just needed a lock, not a redesign. Tap and hold on it and getting a pop up slider might be a happy compromise.
Thanks for sharing your feedback on the mower height adjustment. I’ve shared this with our product team for consideration.
