So I just went through the process of having to remap my entire yard due to… issues…
While I was doing the perimeters of the areas and NG zones I was running the mower and trimmer to make sure the paths were actually hitting the areas I wanted. I had to split the mapping work up over several days because I kept running out of robo battery, daylight, phone battery, or some combination of them. Each time I went to go back out and continue mapping I had to reset the blade height, which I understand and isn’t an issue, but when I would adjust it from the default 2.4 up to 4.0, a second or two later it would revert to 2.5 and stay there. If I ran it up to 4 again it would revert back to 2.5 or 2.6 and stay there, and would have to keep turning it up until it stayed at 4.0. I noticed that if I only incremented it 0.1 at a time about once ever 2-3 seconds, the display wouldn’t revert.
On the last time I had to do this (last night) I tried just holding the increase button. Since it was at night, it was just quiet enough that I could hear the adjustment motors running while I held the button, but looking at the display every couple seconds the number would revert to a number less than 4 but higher than the previous revision. But it did eventually stay reading 4 and at the same time the adjustment motor went silent.
This absolutely feels like a bug that’s not letting you set a height and the robot matching it. It feels like when the app goes to update the displayed value, it also sets the target to that value.
Has anyone else seen this?
