I know fleet management is in the works as it has been for years, but maybe a quick solution is inter-unit scheduling as opposed to inter-unit communication. Previously, the suggested way a fleet would work together is two units working on the same task (i.e mowing) in the same area at the same time. In the meanwhile, if we can have the ability to set one unit to pick up where the other leaves off when it goes to charge, it would achieve the same effect. If I need my driveway snowblowed by the morning and one unit can’t do that, having 2 units work and charge at the same time vs having them stagger achieves the same effect. I know you could just split the area in half, but this would also allow for charging pad sharing instead of needing two in one spot.
This would be huge, but I bet it is a long ways off. As there are so many issues to fix first. Up voted, we can always hope!
Thanks for sharing the suggestion. I can see how this could significantly improve efficiency for larger properties and heavier workloads.
We really appreciate the idea. That said, we’re sorry that this feature may not be a high priority at the moment, but I’ll make sure your feedback is shared with our team for consideration.
