Question about multiple units running at the same time.
Who here knows about running more than 1 yarbo at the same time?
Im assuming that 2 yarbos can run simultaneously off of 1 data center. But can they work the same area at the same time?
Hi there! At the current stage, we do not recommend running two Yarbo units using the same Data Center. Also, we don’t suggest having two Yarbo units work in the same area at the same time, because they are not yet able to recognize each other or coordinate their work as a team.
This may lead to interference or unexpected behavior during operation.
Thanks for your understanding! If you have multiple Yarbo units, the best practice for now is to assign them to separate areas or run them at different times.
I can confirm that what @Yarbo-Forum recommends here is what I have experienced trying it various different ways. It works best with each core having its own dedicated DC and also each DC to be connected to a different subnet/router. If you were going to attempt to run them in the same area simultaneously, I would strongly advise to leave vision enabled on both units. However, the better way to handle this would be to have that larger area carved up into separate areas so that they cannot encounter each other at all.
