Hooks into the slots under the battery cover in order to provide a mountable rig on the top of a Yarbo. Insert HaLow side first (the smaller slot) and there should be enough flex to pop it into the other side slot without breaking. Cutouts for the yellow light and the stop switch are part of the design. Can mount insulation or something else on top of the rig this way to help shield from solar heating effects, possibly helping with battery charging during 90F+ days. Would not recommend reflectix or other metal based as it can interfere with the GPS signals creating multipath issues. Better solution would be to use a foamboard or non EM-interacting material. I have found that this approach is insufficient to only use during charging, but using this when out mowing could keep the solar heating effect down enough to help the heat generated during charging not exceed thresholds.
