I would like to have the option of just one perimeter mowing. I have a narrow area where Yarbo spends a lot of time mowing because one side is not straight it turns a lot. So if you could just do one perimeter pass it would save some time and get more straight lines.
Are those dead ends along the boundary? Maybe one long dead end (or memory path) could cut that and then you could disable the perimeter cuts.
yes that’s it. I’ll have to manage in another way when the trimmer isn’t delivered. yes that was an option. but then I’ll have to make dead ends all the way around the area.
Looks like you already did ![]()
ha ha ha. Yes.
I have. but those on the other side are only needed after the field has been harvested. ![]()
Yarbo of the corn, err children.
Hi there, thanks for sharing your suggestion — that makes a lot of sense for your use case.
At the moment, this isn’t something we’re planning to move forward with, but I’ll continue to monitor community interest in this idea. If more users express the same need, I’ll help pass it along to our product team for consideration.
