Pick the turn direction when doing the 180 into the chargepad.
I have the chargepad somewhat close to the wall and it works to auto park with the snowblower and also with the lawn-mower, but with the lawn-mower it tends to mack into the Drain, or wall. This is because when it turns around to back onto the pad, it always seems to turn around to the left. I have tried to edit the path a little but with no success. Any suggestions how to make it a rightway turn instead of the left?
There is currently no way to determine which way it’s going to zero turn. There is no way to set it either. I would recommend changing the orientation of your docking station to face more outward instead of parallel to the wall. I would also recommend double checking and making sure your recharge setting in working preferences is set to zero turn and not smart turn.
