Why does rain detection limit charging. It will cause it to stop at 80% and no longer charge if it’s over 80%
That shouldn’t be the case. Does it only happen with Rain Detection? When it returns to charge because of low battery does it charge to 100%? This could be an issue with battery management. Unplugging the battery for a few hours has resolved similar issues for others.
Only happens after rain detection. Stop charging and restart charging, it continues normally.
I would start with a reboot if you haven’t, and still disconnect the battery to reset everything. If it persists, opening a support ticket is likely the next step unless another member has other something else to try.
Hi there, we haven’t received many reports of this issue before. You can try the troubleshooting steps suggested by @cobradunn first and see if that helps resolve it.
If you still notice the issue afterward, please feel free to submit a support ticket so our team can investigate it further for you.
