Show NGZ while editing areas, Undo function on Edits
It would be helpful to see the NGZs when you go into edit an area. Currently it hides them. So if you are trying to edit based on where that NGZ you can not end up with the edit you want. Also need the option to Undo map edits and/or get the merge feature.
Thanks for sharing your suggestion. I’ll make sure to pass this along to our product team for consideration.
