Snowblower deadend (a lawn mower feature)
Please add deadend to the snowblower, when a pathway snow is high, it will always get stuck an the end trying to turn, to return. Mayor headache.
Adding deadend to the snow blower will massively solve this issue.
Thanks for your feedback! This feature actually already exists. You can go to the Sidewalk Settings and change the Turning Mode to Straight Drive. Once set, Yarbo will reverse at the end of the path instead of turning, which helps prevent it from getting stuck in deep snow.
I would recommend renaming ‘Straight Drive’ to something like ‘Reverse Back’. Straight drive does not imply it is going to reverse back. At least not to me.
Drive in, reverse out???
Anything’s better than “straight drive”
Hi @JNS, Thanks for the suggestion! We’ve passed your feedback along to the team for consideration.
