- Constant auger overcurrent issues. Almost always at the end of a “line” on the plan when it goes to turn around. If you pause, go into remote control, drive 1 inch and then clear the error, it goes starts up no problem and does the next long line. Stops at the end of that and you have to repeart the process 50x. There is noting blocking chute/auger.
- Repeated “module diconnected” / “module changed” errors. Again, the remedy is to pause, go into remote control, drive a few inches, then it thinks the snowblower has reconnected. Have triple-checked blower seating, lock tabs, cable, etc. Even removed and rettached a couple of times to be sure.
- Seems to go off course by a foot or so whereas previous versions didn’t. When you do, it will stop. But return it the 1’ into the area and watch out - it will completely take you out of the work program and reeset. You of course could restart the program at wheatever percentage was previously completed - but how do you know what percentage it was at? It immediately dumps you back out to main app screen.
Contacted support, they said they don’t see the diconnects/auger issue in the logs. I’m not kidding when say we’re up to 100 stops over the past 24 hours. Have just been watching security cams waiting for it to stop, then fix it in app, then wait 1-2 minutes for the next errant stoppage to repeat the process over and over.
