Stop sign in app
Can you add a STOP SIGN to drop in the map so you can have it stop in the middle or stop because working in that area. or to go to another area. maybe to just cut a high groth area
thanks
greg
How would you envision this working? You can drop a large NGZ(s) if you want it to avoid certain parts of an area. You can turn them off and on at will or delete them. Would that help?
Thanks for sharing your suggestion! At the moment, we’re not planning to move forward with this feature. However, if more users express interest in it, we will revisit the idea.
We appreciate your feedback!
Could it be made to STOP at that no go zone?
Not sure what your intent is, but the only way I am aware of to have Yarbo stop at a specific somewhere is to set it up without a docking station. This allows you to select a stop point when it is done mowing an area. Upon completion of the area, it will drive to that spot and stop. Waypoints would be the other go from here to here type of navigation but that currently only works with the SAM.
If you can clarify a bit more about your intent, might be able to come up with something to get you close or it might already do it.
This request may do what you’re asking - Directives / Commands callable in Work Plan or at a Waypoint
I wrote something up a while ago, but it was buried in a comment, now dug out.
