After owning and using Yarbo for two months, I decided to move on. Below are several reasons why this love affair ended.
Customer Support Challenges
Ineffective Level 1 Support
Level 1 support is incapable of resolving issues—every problem is “escalated” to the technical team. -
Slow Response Times
Responses are very slow and often require multiple follow-ups. Since the support team is based in China, East Coast U.S. support is practically nonexistent. -
No Replies for Days
There are often no responses for several days, especially over weekends. -
Chinese Holidays Affect Global Support
Holidays in China impact customer service for all regions, regardless of where the customer is located. -
Delayed Replacement
It took 25 days to receive a replacement core. During that time, the mower was unusable, and my lawn grew 16 inches tall—right in the middle of the growing season. -
Facebook Support Group Experience
While there is an official support portal, many users turn to the active Facebook group for help. My experience there was mixed:- Moderation Issues: Every post requires moderator approval. Why? Are they trying to suppress complaints or avoid negative publicity?
- Post Rejections: Many of my issue-related posts were not approved. In some cases, an automatic support ticket was created instead. Is this a form of cancel culture? Why prevent customers from helping each other?
Usability Issues
Not Suited for Small or Complex Yards
Yarbo is designed for large, open spaces—not smaller or intricate suburban lawns. -
Damages Lawn During Turns
It repeatedly turns in the same spot, tearing up grass and digging into the soil—especially about 3 feet in front of the charging dock. -
Forced Zero-Point Turns
On my 1-inch ryegrass over sandy soil, the tracks cause significant damage. Support confirmed zero-point turns occur:- When returning to the charging station
- In parallel dead ends where the next pass starts behind the previous one
Poor Obstacle Detection
Yarbo frequently runs into cars, flowerbeds, and other objects, causing extensive damage. -
RTK Navigation Issues
In narrow areas, Yarbo cannot reverse in a straight line and veers off by several feet—despite the RTK antenna being only 20 feet away. Support acknowledged this as a known limitation. -
Frequent Rescue Missions
Major incidents in just two months included:- Running over and destroying plants in a flowerbed
- Climbing a wall during a smart turn, damaging vinyl siding
- Breaking a chain-link fence and getting stuck underneath
Hardware & Software Challenges
Incomplete Object Avoidance
- Only front cameras are enabled—360° vision is not functional
- Supersonic sensors are disabled
Heavy and Unwieldy
The core and mower weigh ~170 lbs, making them impractical for many situations. (Though great for snowblowing.) -
Inadequate Waterproofing
Many users received waterproofing kits or replacement cores. I didn’t receive one, and my core failed due to water intrusion. Fogged-up cameras render vision-based avoidance useless. -
Power Board Failures
There are multiple reports of power boards frying or catching fire. -
Frequent Mower Disc Breakage
Poor object detection and navigation exacerbate this common issue. -
Track Motor Noise
The high-pitched whine is audible from 20 feet away—even indoors. Neighbors have commented, and their dogs bark at the sound. I’ve owned tracked snowblowers that were quieter. -
Fragile Antenna Design
The external antenna breaks easily and frequently. Internal antennas, now standard in most robot mowers, would have been a better choice.
Warranty Concerns
Limited Warranty
The product comes with a 2-year warranty and no option for extension. -
Uncertain Long-Term Costs
Given the product’s unreliability, post-warranty ownership costs are likely to be high.
- Yarbo is not ready for autonomous use—especially not in complex suburban lawns.
- Significant software development is needed across the firmware and app to achieve true autonomy.
- Hardware limitations can’t be fixed with software alone. A hardware revision—perhaps a “Yarbo II”—is necessary.
I truly wanted to love Yarbo and was thrilled when I first bought it. But the honeymoon ended quickly. I hope to return to Yarbo someday—but that day feels far off.
