There's a need to create no go zones on the fly during jobs
Sometimes while Yarbo is performing a job, you can discover an area where it will get stuck or run into an obstacle and the device will create a temporary no go Zone which is fine. However, if that obstacle or issue is permanent, it would be nice to be able to use the red mark that was created on the map to create a no go Zone. The problem is that those temporary no-go zones disappear when you end the job and you cannot create no go zones while the job is running. Therefore, the marking on the map where the problem is located is not available to create a permanent no go Zone. Either we need to be able to create no go zones on the fly during jobs, or we need to be able to save the temporary no-go Zone that appears on the map during a job as an overlay on the map when the job is over.
