Trimmer questions
You did it correctly, now reassemble to see if your error goes away.
Push tabs were on the outside, that let you take the big plastic part off.
That must have been it. I have not received that particularly error anymore. Thanks again.
I am getting the line feed error very often again, but at least now the line is not broken and all I have to do Is reach down underneath the disc and pull on the line to advance it and then let it go on its way.
This of course means it cannot run autonomously, but the damage caused by the trimmer potentially going a little off course makes me hesitant to do that anyway.
You may need to increase the RPMs slightly
Hi there, glad to hear that the loose lock error has disappeared.
As for the line feed error, you can try Bryan’s suggestion and slightly increase the RPM to see if that helps. If the issue still occurs frequently, please contact our Support team so they can further investigate and see how they can help.
