Upcoming Hotfix:Firmware V.3.11.7 & App V.3.16.4
Dear Yarbo Family,
We hope this message finds you well.
Starting November 20, we will begin a phased rollout of Firmware V3.11.7 and App V3.16.4. This hotfix primarily focuses on bug fixes and overall stability improvements. We expect the rollout to be completed within one week.
If you have not received the update by then, please feel free to contact us at support@yarbo.com.
What’s Improved in This Hotfix?
Firmware V.3.11.7:
Optimizations:
  • Fixed the Smart Vision (Beta) offline issue for the Oceania region.
  • Fixed the issue where Yarbo would turn 90° during undocking.
  • Optimized route calculation for Plow Mode.
  • Optimized parallel route calculation for the Yarbo Snow Blower when turning.
App V.3.16.4
New Features:
  • Add Yarbo Store in the profile page.
  • Restored NPS Survey pop up.
Optimizations:
  • Fixed the gray screen issue when opening the Yarbo app on Samsung devices.
  • Increased App connection stability.
How to Update
  1. Ensure your Yarbo is powered on and connected to the internet. The firmware update will be installed automatically.
  2. Make sure your Yarbo app is updated to the latest version, as the new firmware requires compatibility with the newest app release.
We truly appreciate your patience while we prepared this hotfix. If you have any questions, feel free to contact us at support@yarbo.com.
Warm regards,
Team Yarbo
@Yarbo-Forum
I received the firmware update (3.11.7) this morning but the app hasn’t been updated. The most recent version in the Play Store is 3.16.3. When will 3.16.4 be available in Google Play Store?
As of 5 mins ago.
Play Store App Details
@Yarbo-Forum And are there any incompatibilities without the updated app? (It’s not in the Apple App Store either.
@ken.w.gregory @JNS
You should be fine on the 3.16.3 version until the new one posts.
That may be the case but this comes down to planning on their part and communication. Why push the firmware if the app isn’t available and why state this:
It’s just not a good look. If I rolled code out like this at work I wouldn’t be there much longer.
Maybe thats just a copy and paste from the last update which was important for Smart Vision to function properly.
Am I the only one who has problems with the unit every time there is some update?
Core updated to the newest firmware and now I can’t connect to it using the application. There is no new version of the application on Google Play store. And I’m not at the house where I have the Yarbo set up to work.
But application sent me warning notification that there will be snow soon…
I never had any issues with the installation of a firmware update.
Other than the fact that they are pushed without any end user control.
I Updated both of mine today and I just downloaded the currently available production app to verify there are no communications issues with the new firmware. Works fine.
Is your core connected to your home WiFi? If so, that could be a factor. What has been the resolution in the past for your connection issues?
You’re referring to 3.16.3?
Correct
I have wifi always disabled.
I think twice my connection problems have been solved with Yarbo sending me replacement core and once they did something over the air without explaining me what they did or what was the issue to begin with.
When I get back to the country house then I will do the hard restart and let’s hope it will solve my problem this time
It should be available within a day. Thank you for your patience.
Login still doesn’t work even after app update.
My problems looks like are related to Yarbo technicians sorting out my problem that the core is unable to align with the charging pad. I reported it right after I changed the module to snow blower and changed the tracks to winter ones. I have succeeded to get it to charge once on after trying 9 times. But this was only once. All other times I had to drive it to the center by myself.
Yarbo replied that there is something they did what most likely caused the unit to go offline. I do really hope that all is sorted out soon. And not in the way that I will have core number 6 heading towards me to replace the one I have now.
As I have been notably sarcastic before on my posts here on the forum I also feel like improvements are needed to be pointed out.
Yarbo must have hired more people to handle the troubleshooting part. The reply e-mails are arriving with less then 12 hours I have sent my reply to them. This is significantly faster then it has been all year long on 2025.
Looks like things are heading to right direction.
Strange that my app is not even showing that there is newer firmware available
I think it’s because it’s a hotfix and not a regular new firmware release.
I received the app update but no firmware lol.
I seem to get the firmware about day 3 after the release. Which would likely mean Monday for me. ;-(
Just received the new application.
@Yarbo-Forum There is a bug. I opened the new version application and all suddenly it was in faulty Estonian. I changed it back to English but once the application is closed and opened again it is back to Estonian. And then opening the language settings it shows that it supposed to be in English and going back to settings application all suddenly is in English again…
I wouldn’t mind it to be in Estonian if it would be translated correctly. I’m current version my native language in butchered by some translation application.
Second thing is when I open the application now every time it shows that the core has no attachment. It takes couple of seconds to realize that indeed I have snowblower attached.
