Firmware V 3.10.0 & App V 3.16.0 Release Note
Dear Yarbo Family,
We hope this message finds you well!
We’re excited to announce the upcoming release of Firmware 3.10.0 and App Version 3.16.0, packed with powerful new features and enhancements designed to elevate your Yarbo experience.
To ensure a smooth and stable rollout, the firmware update will be deployed in four batches starting August 29th, and is expected to be fully completed by September 5th.
Please note:
  • If your device has not received the Firmware 3.10.0 update by September 5th, please contact us at support@yarbo.com.
  • New app features will only be functional after your unit has been updated to the latest firmware.
Firmware V3.10.0
New Features
  • Yarbo Lab – Precise Positioning Vision System (Beta): Dead reckoning technology provides smoother, more accurate navigation in low-GPS environments, ensuring greater reliability in task execution. For more detailed information about PPVS, please refer to Section One in the following link:
  • Adaptive Route Mode: Improves mowing efficiency while reducing cross-area travel and unnecessary turns.
  • Pathway Vehicle Recognition (All Modules): All modules now support detection of vehicles on pathways.
  • Cloud Backup for Latest Map: The most recent auto-saved map in Yarbo Core is now backed up to Yarbo’s secure cloud.
  • Scheduled Return Options (Lawn Mower & Snow Blower): In scenarios where a work plan is not finished by the scheduled end time, users can choose whether Yarbo returns immediately at the set time or continues working and returns upon task completion.
  • Firmware Update Options: New update modes available: Update Now, Night Update (2:00–5:00 AM), or Skip This Update.
  • Trimmer Adaptability Features: Includes edge trimming based on the original area boundaries, along with a path memory function that enables precise trimming along user-defined routes.
Optimizations & Fixes
  • Large Map Route Calculation: Improved speed and efficiency when planning routes on large maps.
  • Physical Controller Enhancements: Added linear acceleration and expanded the straight-driving control zone for smoother manual operation.
  • Cellular Connectivity: Enhanced stability and resolved previous connectivity issues.
App V3.16.0
New Features
  • Function Labels for Areas: Areas can now be tagged with module-specific labels, improving map clarity and organization.
  • In-App Yarbo Wiki Access: Direct access to product guides and support resources from within the app.
  • Non-Charging Time Setting: Allows users to define periods during which charging is disabled.
  • Plan List Optimization: Plans can be reordered via drag-and-drop, with last execution time now visible.
  • Edge Blowing Mode (Blower): Toggle added to enable or disable edge blowing.
  • Auto Light Mode (Lawn Mower): Toggle added for controlling mower lighting behavior.
  • Obstacle Avoidance Settings (Mower Pro): Provides vision and ultrasonic detection toggles to customize obstacle avoidance behavior on pathways for Mower Pro.
  • No-Go Zone Mapping UI/UX Optimization:
Improved the user experience when mapping and editing no-go zones.
  • General UI/UX Enhancements:
Includes clearer display of NGZ names and selected elements during the editing process.
  • In-App Content Refinement:
Improved clarity and precision of in-app text and illustrations.
  • App Controller Optimization:
Enhanced control performance for a smoother and more responsive user experience.
How to Update
  1. Ensure your Yarbo is powered on and connected to the internet. The firmware will update automatically.
  2. Make sure both your firmware and app are up to date to access the latest features and improvements.
Thank you for your continued support and trust in Yarbo. If you have any questions or need assistance, feel free to reach out to us at support@yarbo.com — we’re always here to help.
Warm regards,
Team Yarbo
Weren’t you supposed to release a way to merge/split areas without having to choose to delete one half of the split? It seems not to be implemented yet. Unless I have to wait for the core to update? Thanks
I do not believe that is in this update. Not sure when that is going to be addressed. If it is in this update, then yes, I would assume you would need to wait for the core to update it’s firmware.
Oh well… Last time I wasn’t updated before the last wave… This is a long weekend here in Canada. I hope I’m updated soon so I can play with the Dead Reckoning settings while off work… Any tips to be updated faster? Wifi? Stop mowing schedule? Or it doesn’t matter?
Yeah it doesn’t matter. You just need internet and the core to be idle for the update to kick off. It will download while working so don’t worry about that. As long as your DC has an internet connection it will update when it’s time for it to.
Not sure what happen, my app updated to 3.16 and now Its always disconnected. I power down and power the Rover, no luck. I unplug the Data center and replug, no luck , reset router no difference. With the app always showing disconnected , I can’t log into the support either. What do I do now?
In my wifi, I do see the Base, Rover and HaLow
Do you see OFFLINE with the chain in the center? If you hit the chain, does it connect? Are you within Bluetooth range? If you are and it still won’t connect, try adding a new Yarbo and see if it shows up.
You can submit a ticket by emailing support@yarbo.com or going to support.yarbo.com and clicking on my area.
Yes I click on the chain link, it rotates and says not connected to Network. I am next to both the Data center and Rover. I tried adding New, it brings me back to the one I’m registered to. I am connected to the Wifi that the Base is connected to. I uninstall app and reinstall, no difference as well. I can connect to Rover hotspot, Base and HaLow, but the app isn’t working right.
Ah, ok. This is a 23. You may need to use the Yarbo Tool to reset everything. Sounds like it could be a problem with your base. I have never owned or dealt with a 23, so I don’t have a lot of experience here to guide you, sorry.
How do I do that ?
I don’t have a Yarbo Tool I believe. Even in the app, I don’t have an option to reset anything.
This happens everytime there’s a major update, last time they have to force update the unit. Seems like they have to do it again somehow, but this time it’s worse, because even I can’t log in on the app to see any info except the forum.
Edit: I also have a New Base, with it plugged in, I am unable to go through the set up to recognize the new Base. Uhoh.
I don’t know if this will be helpful or not, but I will share it in case it is. If you have a ticket number, you can share it here and the moderator will follow up on it for you. Note to anyone else this tool ONLY works with the 2023 Yarbo Universal Body and NOT the 2024 Yarbo Core.
Anybody tested what happens if you pick the « finish plan » option and it overlaps with the next plan? Will it queue the next plan or skip it?
I’m betting it skips it.
That’s too bad… problem is if it rains, or if you slow down the thing, or slow charging because of heat, and your schedule is a tight, then it will screw up everything…
It’s a step in the right direction though. Small tweaks to get by until the big ones I guess.
Fingers crossed
I just received the update this afternoon. I’ll see what I can squeeze out of it!
Have you had a chance to follow the guidance we shared in your support ticket, and did it help resolve the issue? If not, please let us know and we’ll be happy to investigate further.
I tried the 3-5 second power on, went to app, wifi, it never connects. My phone Bluetooth is on as well, but no change. I use both Android and iPad. No luck.
Hey Bryan, I follow the instructions to get the Yarbo Tool, it isn’t in the Knowledge Base like it used to, seems like Yarbo may have moved it somewhere….. I’m still searching for that tool.
