Upcoming Update: Firmware V3.14.0 & App V3.19.1
It will deliberately try to eat them.
So it looks like once you enable Tow Mode, it overrides everything. Settings for Areas only show the Tow options. You have to disable the Tow Mode to do anything else. I guess it makes sense, just wasn’t expecting it.
Correct. It also will not plan a path to recharge to the dock. It will error out. This is by design for safety.
Ok, now for the bad. The boundary speed restriction is completely gone. It attempts to mow the boundary at the same speed as the field. My first cut this morning wasn’t an issue, but it just tried along my aluminum fence edge and hit it 6 times in 30 ft. It managed to navigate it by backing out repeatedly, but it wasn’t pretty. Who’s got feedback on this “feature” I would love the 2nd and subsequent laps to be at field speed, but it can’t manage the 1st lap running on Fast! The red in the pic are all the fence strikes.
That’s an interesting bug. It is not a feature. I also have not experienced that yet. If you reduce your area moving speed to slowest, does it help?
Yep. The border speed follows field speed. Rebooted core and tried reducing and increasing the speed with same result on the border. The only thing odd I’ve done is enable Tow Mode and disable it before this plan. I rebooted just now to confirm the results.
Is the mapped border consistent with your expectation or did it possibly shift?
Borders all look correct. It was screaming along the fence line. It can’t make corrections and maintain the accuracy at that speed. The field edge at the back is cut great. A little variance there isn’t terminal. It does not look like map drift. It was perfectly aligned on the charger when the plan was started and this my best GPS area. I was seeing 30+ sats on both.
Edit: Ticket #225638
Well I guess we found the first hotfix
Hot fix, but why? Lol
I’m going to let it complete this area and start another. I’m pretty sure I went into the edit mode for Tow Mode in this Area. I’m also pretty sure I didn’t change anything. If the speed issue is limited to this area, we’ll know where to start. I’ll get a ticket going once I have that data. I was at work when I ran the other Areas so can’t say what it did.
Edit: For reference fence line in distance.
Edit #2: Happening in all Areas Ticket #225638
With ride on, I pull a leaf sweeper behind without bag to spread out grass clumps. Will tow mode allow for this with pro mower or is it only designed for SAM use?
Tow mode works with the mower module but you are either in tow mode or you are in mower mode. You can’t do both yet, unfortunately.
Same happened to me
update: mine just randomly rebooted after an hour or so (I heard the Ready to Work) and checked the app again and it was showing the firmware as updated
Hi there, this behavior should not happen. Could you please submit a support ticket and provide the estimated timestamp when the issue occurred?
Our support team will review the logs and further investigate what may have caused the unexpected behavior. Thanks for your help and cooperation.
Could you please update your ticket with the requested information? This will allow our team to review the details and continue with the next troubleshooting steps to help resolve the issue.
Thanks for your patience and cooperation.
I also have now the new firmware and the new version of the application.
I have 6 areas. When I choose one for the areas and send the robot to work then on map view I only now see this area where I sent it to work. Other areas have disappeared. When I stopped the work then all other areas appeared again.
The other thing is that the GPS icon on the application now is flickering between green, yellow and red. Without Yarbo stopping its work. Must be some new bug. It wasn’t doing that before today’s update.
I believe if it was actually in the red status with GPS it should stop immediately. Or maybe not…
I also just reported this to the support but they somehow have been silent for a week and do not reply to my open ticket. I have sent them now 4 emails without getting any replies…
@Yarbo-Forum how long are the ques for the support nowadays?
Hi, I don`t quite follow where support need this info, on this case?
-Your order number.
-The email address associated with your Yarbo account.
-Your shipping address.
Anyway, thank for your help, now firmware seems to upgraded latest.
@Yarbo-Forum
I am unable to connect with my unit and not home to try restarting. Version setting shows no ( 0 ) firmware installed.
Any ideas?
